sandisk extreme
Hi guys , I would like to know if the sandisk extreme iv udma enabled is suitable for the nikon D700 ! If not which one would you suggest > Salute drecked
http://pct1.sandisk.com/ProductList.aspx?DeviceID=2179
extreme IV card are compatible but the d700 supports UDMA 6 so if you want the very best performance i would suggest Extreme Pro
thanks drlucky, i’m glad i held of ,    It cost me a lot of money so I would like to get the best out of my camera !
thanks jamieson , your on drlucks wave lenght .
