Newbie
Accepted Solution
problem in Formatting Micro SD HC Card
Hello there
I ' have a problem for Formatting my micro card .
When I want for Formatting card appearance this error
guys help me plz
good luck all Smiley Happy
Newbie
Re: problem in Formatting Micro SD HC Card
There is a switch usually on the SD cards. If you are using a SD card reader to preview the files that are on the micro SD card, there is a switch on the side that needs to be set to off.
Newbie
tnx
but i havn not adaptor !
i use micro sd ram-reader to usb
so how to formatting ?
and sry i can't speak eng well Smiley Sad
SanDisk Guru
Newbie
is there anybody to help me ?
SanDisk Guru
Yes. Did you click on the link in my reply and follow the advice given?
Newbie
yes i did . but not worked  :X tnx
SanDisk Guru
Returning the device or calling Sandisk Tech Support for a warranty replacement did not work? :smileyfrustrated:
Obviously you didn't because that was the advice I gave in the post I linked to. Thanks for wasting both yours and my time though.
Newbie
[ Edited ]
tnx Heart
but it's not possible.
because i'm persian and i can not use the warranty service Smiley Sad
Newbie
[ Edited ]
If you bought it online, and have used amazon, they accept returns free of charge usually.
Check with the seller.
