Newbie
open my USB Extreme 64GB with password on my android phone options
Hello
When I Plug in my USB drive on my Android phone, all files appear unless the files I Downloaded and l've protected with a password. How ouvrirs? Thank you
SanDisk Professor
Re: open my USB Extreme 64GB with password on my android phone options
that is also correct, your password protected files can be opened only with the secure access software on  a windows or mac computer
Good Luck
#Missing the keyboard? Press F1 for help#
Newbie
Is there any program atau playstore to unlock password On Sandisk?
