Newbie
Sandisk Micro Extreme Pro 64 gig
Card was being used in a DJI Phantom 4 Pro and is regestering in the drone but cannot be seen anywhere on the computer when plugging it in via a card reader.
a 32 gig version can be read.
Anyt ideas on how ot get it back
SanDisk Guru
Re: Sandisk Micro Extreme Pro 64 gig
Make sure the card reader you're using is SDXC-compatible. Not all are.
SanDisk Guru
also what OS are you using? the OS will need to support the exFAT file system as well.
