Newbie
SDXC 64GB card Problems
Footage shot on Sony A7rii using Extreme PRO  SDXC card I cannot download the clips to ClipWrap the message said
The operation could not be completed
 I use sdhc cards in my Sony NEX-FS700 and the footage imports into ClipWrapwith no problemdo i need to down load software for the cards?. I am on Mac OS Sierra 10.12.6
SanDisk Guru
Re: SDXC 64GB card Problems
there is not any software for the card. can you manually copy the data off the card using finder? if so you may want to contact ClipWrap support.
