Newbie
SD card won't format into external storage
Hello SanDisk community!
My phone is a Moto G5 16 GB :
I can't format my micro SanDisk Ultra 64GB SDXC I ... I've tried already :
- to format it from the moto G5 itself throught the storage menu (formating operation runs quickly but my card won't be recognized)
- to format it from another android LG phone (this time the formating operation was stuck and didn't run till the end).
- to format it from computer running Windows/Linux (I got this message that I don't have permission to format the SD Card)
So as you can see any ideas are welcomed :-)
Here is the story of the SD card I am trying to format :
Nov 2017 - brand new moto G5 16 GB of internal storage. I bought this SD Card and setted it as internal storage to extend my initial internal storage.
June 2018 - I can notice some bugs with my SD card : some applications installed on SD card will immediately interrupts as soon as started ; Camera isn't able to take pictures anymore because of SD card...
July 2018 - Here I am trying to fix the problem reusing my SD as external storage.
Hope I've been clear explaining my situation,
Good day,
Hugo
SanDisk Guru
Re: SD card won't format into external storage
You most likely will have to re-format the card to FAT32 with a tool such as from the SD Association
