turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Re: Memory card not deteced by mobile or computer.[ Edited ]Options
05-20-2012 10:58 AM - edited 05-20-2012 10:58 AM
Sounds like maybe you formatted it wrong. What size is it, and with what program/device did you format it?
2GB (& less) should be formatted as FAT. 4GB (& larger) should be formatted as FAT32.
0
Re: Memory card not deteced by mobile or computer.Options
05-22-2012 09:30 PM Good morning,
I have a SanDisk SDHC Card 8GB, that as of this morning cannot be detected by my laptop (Acer) and previously have had no issues. Further, I inserted the card back into my camera I had taken it out of (Nikon) and my camera shows a message of "this card cannot be used", when it is loaded with pictures and has been used for almost a year now. Can you help me troubleshoot or tell me where to take it to fix it? Not worried about the card itself but the pictures are irreplaceable! Thanks so much!
jamie wordgrl7@yahoo.com
0
06-12-2012 05:24 PM How do I get started with memory card when using on laptop? Works fine on tablet.
0
06-18-2012 07:26 AM suddenly my 8 gb sandisk memory card cant detected by phone or pc.pls help me
0
06-22-2012 02:26 AM I have a Sandisk 4GB microSDHC card which was working fine for the last 1 year. Suddenly, it is not been detected by my mobile phone nor by my PC. Is there any way I can retrieve my data ? I have checked the Microsoft's Update, but it is of no use.
Please guide me I need my data back.
0
07-07-2012 01:09 AM I have an 8 GB mobile microsdhc card with adapter. It reads fine in my phone - but not detected in my HP PC. Can't seem to find any solutions. Any suggestions? Thanks
0
07-22-2012 06:09 AM 2gb & 4gb memory card not detected by any mobile & pcs
0
08-09-2012 08:53 AM I purchased new Mobile microsSDHC Memory Card. But it is not detected by either mobile of my computer. Please let me know why?
Regards,
Padhye
0
09-04-2012 09:58 PM
0
11-04-2012 11:31 PM Hi, my name is Shah. i'm using card reader to open my Micro SD card in Computer, bur error shows that "Insert Disk". What am i do???? |
