Newbie
Re: How to repair micro sd 16gb card? It shows 31mb
My card is doing the same, i think its something with the manufacturer, hopefully they will replace it, i'm calling tomoro
Newbie
Newbie
Hey, I had the same problem with 32 gb microsdhc card. It use have a capacity of 31.2 gb but then it crashed and only read 512 kb. I tried formatting tools and everything, that didnt work. I then put it into a digital camera and formatted it which got it back to 31.2 gb Smiley Happy
Newbie
MY 16GB USB FLASH DRIVE IS BAD AND I JUST BOUGHT IT I CANT COPY FILE INTO IT, EACH TIME I TRY COPYING FILE INTO IT THERE IS ALWAY A MESSAGE THAT SAY RIGHTLY PROTECTED
SDCZ50-016G-B35
SanDisk Guru
SDCZ50-016G-B35
If you look around, there seem to be quite a few people having this problem, with no known solution, either from other members or SanDisk themselves.
The only thing you can do is return it.
Newbie
 How to repair micro sd  2gb card? It shows 31mb
i have to recover my files please help me
Sridhar
NIvas Communication
SanDisk Guru
Read Message #8 of this thread. If that doesn't work, then see the post directly above yours.
Newbie
I am stuck with the same problem. My Micro SD threw up on me , when  one slightly "fat" sized MicroSD adapter, go stuck in a built in Laptop SD card reader and I had to use clippers to get it out. The adatper  had scratches on it but the microsd should have worked. Now it shows 8mb instead of 4gb
There has to be some BLOCK level formatting utility that wipes clean the data.
How about Fdisk in linux or gtparted. Could someone post their exp with those.
THanks
Sam
Newbie
This may help anyone who has a simular problem with an SD memory card shoing the wrong size. Use the SD formatter 3.0.  It can be downloaded from the SD association's website.
http://www.sdcard.org/consumers/formatter_3/
Choose options, then change Size Adjustment to ON.
Format your SD card:
Refresh:
Your SD card should now show the correct size
Newbie
https://www.sdcard.org/downloads/formatter_3/eula_windows/
