turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
How to repair micro sd 16gb card? It shows 31mb[ Edited ]Options
08-28-2010 08:00 AM - edited 08-29-2010 05:33 AM I have just received used HTC HD2 from ebay. It has original micro sd card 16gb. But the HTC does not whant to recognize this card. Every time when I insert it, the device ask me format it. And if I agree it shows a message after a second that format was successful but I can see this card in phone.
My PC is XP SP3 and use Windows Media Player 11 to sync my Fuze. The Fuzeis 4G and is firmware version 02.02.26A. I recently purchased a Polaroid brand (didn't have sandisk brand) 16gb micro SDHC for it. When I put the card in my Fuze didn't recognize it until I upgraded the firmware to the version listed above. The Fuze will only format the card to a 2gb capacity. I went ahead and did it anyway hoping it would show 16gb instead of 2gb.....stupid I know. Anyway, afterwards I attempted to re-format the card on my computer using one of those flash drive style readers. When the format dialog came up my only options were "FAT" instead of "FAT32" and a disk size of 30mb. I cancelled it and now the computer will not recognize the card unless I unplug and replug the drive.....doesn't matter whether or not I removed and re-inserted the card. How do I get the card set up to work with my Fuze? Do I need to get a "proper" card reader in order to format SDHC cards?
0
Re: How to repair micro sd 16gb card? It shows 31mbOptions
08-29-2010 06:26 AM Beware of cheap cards being sold on Ebay. Many are fake. Apparantly there are those who try to pass off old low capacity cards as 16 GB cards. Some cards are listed as 16 Gb, which means 16 gigabits, or only 2 gigabytes. Many are fooled into thinking this means 16 gigabytes.
0
Re: How to repair micro sd 16gb card? It shows 31mb[ Edited ]Options
08-29-2010 09:54 AM - edited 08-29-2010 09:55 AM Thanks yes I know. I read alot of information about it. I wanted to buy 32gb micro sd card but now I dont.
But this is original SanDisk card wich goes with htc hd2 with serial number.
0
08-29-2010 02:24 PM
Did you try formatting the card in your pc using the card formatting utility? http://www.sdcard.org/consumers/formatter/
0
08-30-2010 03:08 AM Yes I did. It shows 31mb too if card is visible in card reader and if I try to format I can see the message that card is write protected but it don't. The switcher on the card holder not in write protected state.
0
09-13-2010 05:40 PM
I have the same problem with a 2GB Sandisk MicroSD Legit boxed purchase from a supermarket. It was fine, showing the full 2Gb and happily accepting files. A month later Neither my linux nor windows XP machine report the card as having a partition table and also report the unformatted size of the disk as 31MB meaning that I cant dd a copy of the data off the device. The Panasonic SDFormatter software reports the card as 30.6MB. Is there a fix that will restore the previous state or at the very least let me format my 2GB card to more than 1.5% of its nominal size?
0
09-13-2010 05:42 PM
possibly worth mentioning that this card has not been used in any phone or media player, just proper card readers attached to desktop computers.
0
09-13-2010 06:46 PM do a google search for "hp disk storage format tool" download that and use it to format the card. if it does not fix it the card is bad and will need to be replaced.
0
09-14-2010 09:44 AM nope the HP tool also reports 31MB. I guess the card was just faulty, rather annoying that it didnt fail untill the returns period was up.
0
09-14-2010 12:24 PM - edited 09-14-2010 12:27 PM Me too. 30.6MB and nothing helps |
