I have a Kingstone reader that don’t read Sandisk CF 32 gb in my Mac.
The same reader read other Lexar CF in my Mac
The same reader read Sandisk CF 32 gb in other computer
The problem there is only with this Sandisk CF 32 gb in my Mac because also if I connect my camera with usb cable it doesn’t read it.
Someone can help me ???
Thanks…
cacho
2
Hi Maxventuri,
Dear member of SanDisk Community, welcome.
Mmm… Friend, I think that the problem, is that Sandisk CF 32 Gb need more power, and this port of the Mac, does not supply enough power.
Please, try on other ports of the Mac, to see what happens.
Luck, and then you tell us, what happened, please.
Regards, Alfred. (Google translated)
rhodesv
3
How about if you run an OS update? Thought that might have helped.
