Just wondering if it is best to delete files when finished copying by using camera delete or from desktop clearing all files or re formatting disc?
It is a 4 gb
THanks
best to format the card in your camera
So don’t delete individual files just format once files are copied?
Also if you do delete individually should your format from time to time to get card clean>>
Thanks
deleting individual files is fine but yes you should periodically format the card
