kjc
Newbie
Any difference between Extreme and Extreme PLUS micro sd?
[ Edited ]
Is there any difference between the 128GB extreme PLUS microSD card here:
https://www.amazon.co.uk/SanDisk-Extreme-microSDXC-Memory-Adapter/dp/B06XYSVX64/ref=cm_cr_arp_d_prod...
and the 128GB extreme microSD card here:
https://www.amazon.co.uk/dp/B06XX3X9JD/ref=psdc_1345826031_t2_B06XYSVX64
As far as I can see they both seem exactly the same with read speed up to 100MB/s, write speed up to 90MB/s, with all the same classes:class 10, A1, UHS-1 U3,  V30
If the extreme plus is actually any better than the extreme then I might get it as it's only £6 extra, but if there isn't any difference I don't want to waste £6 on nothing.
Thanks
SanDisk Guru
Re: Any difference between Extreme and Extreme PLUS micro sd?
functionally they are the same. i would go for the cheaper one.
