Go To
turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
(anon)
N/A
0
My computer wont read my cardOptions
02-16-2009 09:11 PM
i put my microsd card in the adapter card and plugged it in to my computer and but nothing happened after that, i even looked in the my computer folder and i cant find how to acxess my card how do i do that?
Solved! Go to Solution.
(anon)
N/A
0
Re: My computer wont read my cardOptions
03-01-2009 08:54 PM
Yeah I am having the same problem. I have been able to use it since I got it on the 12 of January, but now all of a sudden it wont connect with my computer, same as with my sister-in-laws memory card drive. So, whats really going on?
(anon)
N/A
0
03-08-2009 06:50 AM
Yeah, same problem! this sucks... it maybe b'cos you have password. i cant del my own pass because i have forgotted it =S
(anon)
N/A
0
03-18-2009 07:19 PM
I have the same issue. Tried to use the card in three different computers with Vista and Xp...Still no luck...this sucks. Works in my phone fine.
(anon)
N/A
0
03-19-2009 10:15 AM
what capacity of cards do you have? if they are larger than 2GB make sure your reader is SDHC compatible.
(anon)
N/A
0
03-29-2009 06:17 AM
i have a 2meg m2 card and the adapter that come with it but my laptop wont read it is there any software that i can get which will help read it
(anon)
N/A
0
04-14-2009 05:19 PM Same issue here. neither of my computers will read the 4gb microsdhc card. My Kodak camera sees it but it wants to keep formatting it but never does.
FIX THIS PLEASE
(anon)
N/A
0
04-14-2009 05:51 PM Im now going to try it in my new Samsung Eternity phone (SGH-A867) SW version A867UCHJ3 ( it works in the phone) btw THE CAMERA IS A KODAK DX6490 (the camera keeps wanting to format i, but can't) I'll buy a new card reader and see if that lets my computer see it.
(anon)
N/A
0
04-23-2009 12:45 PM i have the same problem my 4GB SDHC memory card works fine in my phone but my computer wont read it, i have windows xp. "make sure your reader is SDHC compatible" how do i do that?
(anon)
N/A
0
07-07-2009 07:05 AM
I am having the same problem. I just bought a 4GB Micro SDHC yesterday, but when I put it into the slot in the computer, it is unrecognized. I have no clue what what to do. I feel better knowing I am not the only one having this problem.
