Accepted Solution
How to fix Corrupt 2GB MicroSD?
Would anyone be able to tell me how I could fix my MicroSD 2GB? I have Paragon Partition Manager 9 and was told I should be able to fix it with that but not to sure how to use it? The memory card just comes corrupt and slows my computer down when put into the card readers and won't recognise it.
Any Help is appreciated
Thanks!
Re: How to fix Corrupt 2GB MicroSD?
What card reader are you using?
Have a microSD/Transflash Adapter to go in the card slot on the PC and  a sandisk 2.0 microsd USB card reader.
What exactly happens when you insert your card?  Is it recognized by My Computer?  It sounds like you are using an internal reader...is this reader rated to read 2GB-capacity cards?
When I put the card adapter into the slot it just slows the computer right down and won't detect it. It use to work absolutely fine also I have an 8GB microSD aswell and its working no problem.
What happened with your card that you needed to use Partition Manager?
Message Edited by Warl0ck on 02-12-2008 11:03 AM
