Go To
turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
(anon)
N/A
0
Is there a current or NEW Extreme III 30mb Reader coming out for SD version??Options
10-27-2008 09:21 AM Is there a current or NEW Extreme III 30mb Reader coming out for SD cards? I can't read my 4gb Extreme III 30mb SD card in my built in SD reader on my older WinXP machine. The card worked okay on my Vista 64bit laptop but took more than 6 minutes to transfer a gig worth of images (417 to be exact).
Anything???
I am surprised and disappointed that a reader isn't readily available for ALL versions of these memory cards.
Thanks, BlueKnight
(anon)
N/A
0
Re: Is there a current or NEW Extreme III 30mb Reader coming out for SD version??Options
12-21-2008 01:41 PM
Try the newer sddr189 or 199. It can use the card on it's maximum speed.
