Accepted Solution
8GB SDHC via CF card adapter
I would like to use the 8GB SDHC Extreme III card in my camera Canon 5D via CF card adapter Minolta SD-CF 1. Are this SDHC cards compatible with this adapter to uusing in cameras? SD card is more versatile for me.
Thanks.
RB.
Re: 8GB SDHC via CF card adapter
You would need to contact Minolta and ask them if their SD-CF 1 is compatible with SDHC.  It probably is not going to work, but they would be the only ones to know for sure.
