(anon)
N/A
0
Accepted Solution
Power consumption differences
My son will be on a back country trip with NO access to recharge batteries, and a limited number of replacement sets for his camera.  We have already gone to lithium for long lasting the only area I have not had a chance to look at is the SD card.  Is there a power consumption difference between the various SanDisk SD cards?
(anon)
N/A
Re: Power consumption differences
Sure, a little, but it is so small that it is not enough to matter.  Keeping the LCD on the camera turned off, and limit the use of flash, will be the best way to extend your batteries.  Those suggestions, and using lithium batteries like you are, are the best ideas.
