(anon)
N/A
0
Accepted Solution
Will the SanDisk Extreme 60MB/s UDMA5 CompactFlash Card work in a Type II CF slot?
Hello!
I've just placed an order a SanDisk Extreme 60MB/s UDMA 5 CompactFlash Card from a online retailer and I was wondering if this CompactFlash Card is compatible and will fit and work in a Type II CF slot at least at lower speeds???
Thank you so much for responding.
(anon)
N/A
0
Re: Will the SanDisk Extreme 60MB/s UDMA5 CompactFlash Card work in a Type II CF slot?
if the card port is type II only then no it will not fit. Type I cards are slightly wider. that being said however most slots are typeI and type II compatible but you may want to check the the device manufacturer.
(anon)
N/A
0
Yes, my card reader has full compatibility with Type I cards as it says CF Type I/II on the box instructions, so does that mean im fully ok then???
(anon)
N/A
0
The card is working fine in my card reader.
Thank You!
