Naming
I try to rename my flashdrive, it says i have to log in as an administration account
anyone know how to fix this?
Re: Naming
Do you have admin rights on the computer you are using?
1. Go into "My Computer" (Computer for Vista)
2. Locate the flash drive in the window.
3. Right click, choose "Properties"
4. When the properties window pops up, Choose "Security" tab accross the top.
5. Make sure that you have "Full Control" on that device checked in the list.
Then try to rename the device from there.
Let me know if this helps.
LJ
