Sansa Clip Zip Firmware 01.01.12
Firmware is the software code that powers your Clip Zip.  You can think of it as the operating system.  SanDisk actively and periodically updates the capabilities, functionality, and reliability of the Firmware.  For an optimal experience with your Clip Zip, SanDisk recommends that you update your Firmware with each new release.  It’s fast, easy, and free!
The Sansa Clip Zip ships with firmware version 01.01.12. To Reload your firmware please use the manual firmware insalation instructions below.
Windows Users can Connect the device in any Mode and follow the instructions below.
Mac and Linux users can connect their Fuze in MSC or Auto Detect mode and follow the instructions below.
MSC mode instructions:
  • Turn on the Clip Zip
  • Navigate to  Settings  on the menu of the device
  • Scroll down to System Settings
  • Scroll Down to USB Mode
  • Select MSC
 Sansa Clip Zip Firmware 01.01.12 Download and Installation instructions
Manual Firmware Update (Download and Instructions)
Manual Firmware Update (All Regions) - Click here to download
All languages are now in one firmware version. After firmware update you will need to select your Language and Region preference.
• Remove any external card from the Clip Zip before performing firmware update
• Ensure your battery is > 50% full.
• Plug in your Sansa Clip Zip to your computer.
• Extract the  clpza.bin  file from the .zip file you just downloaded into a folder on your computer.
• Once extracted, drag the file to the root directory of your Sansa Clip Zip.
• Disconnect the Sansa Clip Zip and let the firmware update begin.
• Once it finally finishes doing its update, it will turn itself off.
• Turn the Clip Zip on, Select your language and region preference
• Once its back to the main menu, head to “Settings” >“System Settings”> “Info”, and verify the “Version” is now 01.01.12"x".
I think you have a typo in the download link, should be:
http://mp3support.sandisk.com/firmware/clipzip/clipzip01.01.12.zip
BTW, nice to see its still the (fantastic) Clip+ hardware inside :slight_smile:
Note that, after applying the firmware, you will need to re-set some of your player’s settings, if changed from the default.  E.g. FM presets, USB mode, 12-24 hour time.
Is there the shipping FW or was there a change already?  I couldn’t find release notes for it.
This is the initial release firmware as shipped with the Clip Zip.
Bob  :smileyvery-happy:
HI,
I got the new Sansa Clip Zip from sandisk today. Its very cool I love it:smiley:
I also downloaded the Zip firmware, and i am trying to remove the radio as i did on my sansa Clip+ with the clpp.bin
I changed the clpza = to clpzg to remove it , but it dosent work the same as all other firmware did .I tried G=P=S but none work
I would appreciate any help!
@ubtapes wrote:
HI,
Dont bother eding that stuff. Just go to settings>customize> And then deselect radio. It will go away.
Thanks for the reply,
I know this, but I am looking for a real solution, its too easy to turn it back on
We are selling it to communites were radio is not allowed! so I need a permanant solution or something like the clppg.bin which we had for the sansa clip +
Is there a more effective solution for that?
This functionality will be added in a future firmware update. To answer the next question no we do not have an ETA for when it will be added.
Forum Admin
slotmonsta
Forum Admin
slotmonsta
Pleasepleaseplease add back in the elapsed time for a track along with track no./total track listing like in the old Clip/Clip+.  :smiley:
I do see that there is a new version 1.15 out there, is this already what we can change it to G Format?
@ubtapes wrote:
Why don’t you just buy it from the correct distributor for your geographical area to begin with? Sounds to me like you’re trying to circumvent a legality and/or buying them cheaper somewhere else and then trying to cover your tracks by ‘removing’ the radio.
Sure glad I don’t live anywhere near where you’re doing business.
If I may ask, why is radio not allowed anyway? And what’s to prevent your customers from just downloading a non-“G” firmware and re-enabling the radio? Or are they forbidden to use the internet too?
I don’t see anything shady about conforming to a local regulation.  Sellers can ship worldwide, and there are regions with legal requirements regarding radio reception.  In some countries radio reception is taxed, or there’s a device fee, etc.
Being able to install the correct firmware for a given region is important to comply with local regulations.  Previous Sansas allowed this, so the capability makes sense.  The end user can circumvent the cabability, but it meets regulatory requirements.
Just think of the EU requirement to inhibit the volume level.
Bob  :wink:
Right now, with the Clip Zip’s limited international release–only in the U.S. right now, as far as I am aware–I can understand some people wanting to buy now in or via the U.S., if possible, so as not having to wait for a later release date in a particular country, and then adapting the firmware as needed.  Always fun to get the latest technology or gadget.  And these wee things are easily mail-able or otherwise transportable.   ;).
If the manufacturer is doing this, then no. On previous Sansa models, SanDisk had different hardware configurations made up at the factory, or particular production runs, if you will that had the approriate firmware installed to conform with these limited markets; case is point being the FM Radio restriction. These units would make it to the end user fresh (and sealed) from the factory, compliant with the local legalitiies.
However, if someone (I presume a retailer or ‘local’ ditribution vendor) is attempting to get a jump on the competition or buying them from somewhere they are not supposed to in order to give themselves an advantage (price or otherwise) and opening up the factory-sealed packages to manipulate the firmware on them to make them ‘compliant’ then yes, I have a problem with that.
Maybe SanDisk has changed the way it handles distribution in different international markets from the way that it used to, but I certainly wouldn’t want to buy what I assumed to be a ‘new’ unit only to find out that someone not factory or manufacturer-authorized had already opened it up and buggered around with it.
But let’s keep in mind, we’re only talking applying SanDisk’s own firmware in one of its (to-be) variations, to circumvent the radio capability.  I really can’t see an issue with that (and also not being forced to wait until a particular configuration might finally arrive in one’s country–getting a new gadget and not having to wait for it is nice).  And as a consumer, I like the ability to bring the radio back, at my will.  Of course, one always has to be careful with whom one is buying from, whomever that might be–a return policy is mandatory with all electronics, in my mind.
Hi Tape worm,
Let me explain myself,
I am buying the Sansa direct from Sandisk, or any other legall resller.
I don’t have anything against Radio whatsoever. However, since this Sansa Clip has become so popular in our communities thanks to its small size and capabilities evreyone wants to have it. The problem is though that in our communiteis Radio is not allowed , and that is what the customers are requesting from us.
If anyone is requesting it with radio then I have no problem to sell it to them as is.
My issue is mainly concerned to serve my clients better with the better product!
