Newbie
Ultra Dual USB Drive 3.0 disconnecting on File Transfer
Hello.
I hope someone can help me out with a problem?
I have recently purchased the above item and when I try to transfer MP4 files from my Mac to the device, it keeps disconnecting part way through, the re connecting. I get the error code 33?
Many thanks
SanDisk Guru
Re: Ultra Dual USB Drive 3.0 disconnecting on File Transfer
what version of OSX are you using?
Do you have any other removable drives that are working correctly with the Mac?
does the dual drive work normally on any other systems?
Newbie
Hello.
I've only used it on my Mac. I have other USB devices in the computer which all work fine. I'm running on 10.12.3
