usb flash drive not recognized
I have a sandisk cruzer 8gb flash drive, and 3 computers. the flash will work on 2 of the computers but not the 1 any ideas why. thank you
PS, the 1 computer will reconqize other usb devices
any ideas why
Oxidized USB 3.0 contacts in the USB port can cause this.Ā  A brief clean up with emory paper should work.
I will try that, but the port on just the 1 computer does detect other usb devices just not the sandisk.
SOLUTION
  1. Open Run (Win+R)
  2. Type ā€œcompmgmt.mscā€ , click Ok
  3. In left side click Disk Management , the Disk management window will open.
  4. In right side at the bottom you will get this option ā€œUniversal Serial Bus Controllersā€. Expand this by click on ā€˜+ā€™ button.
  5. You will see all the list of USB controllersā€¦ you will find a ā€œUnknown Deviceā€
  6. Right click on Unknown Device and click Uninstall.
  7. Restart your system. Now connect USB, window will automatically install the drivers.
Thank you for your reply. I do not have the option ā€œUniversal Serial Bus Controllersā€. In the Disk management window.
I also have the similar problem after upgrading from Windows 7 to Windows 10. I tried different USB ports on my laptop and still no luck.
Sloved my problem by buying a new Front USB Audio I/O Input Output Control Panel Board Card. .
Mine was fine but no drive letter was assigned.Ā  I just had to assign the letter in disk manangment and all worked again.
I had the same problem and it just turned out to be a drive letter conflict
Windows is notorious for assigning the same drive letter to different products.
Rony_Kurana has the correct solution that solved my issue. He just meant to type Device Manager instead of Disk Management.
No ā€œUnknown Deviceā€ found.
