Newbie
my cruzer was locked read only by system how can i unlock it,it won't format or anything
SanDisk Guru
Re: my cruzer was locked read only by system how can i unlock it,it won't format or anything
[ Edited ]
What operating system are you running on your PC?
And from a friend named jaclaz:
Can you:
  1. try that same stick on another PC
  2. try another stick on that same PC
  3. try that same stick on the same or another PC with another OS (maybe a Linux LiveCD)
This would exclude *any*
OS
or
PC
specific issues and pinpoint the issue "inside" the stick.
With the Cruzer plugged in open a My Computer window and RIGHT click
on the device's drive letter.  Then click on Properties and report what
File System is shown.
To verify the device is read only, in Windows open a Command Prompt and execute:
ECHO Hi, I am echoed to a text file>?:\mynicefile.txt
 replacing the ? with the cruser's drive letter.  Post the results shown in the Command Window.
Ed
Newbie
I have a 32 GB SanDisk with the same problem. I've used it for 4 months with no problems (17GB out of 32GB) and just this week started this "The disk cannot be written to because it is write protected. Please remove the protection from the volume in drive G:" I got that very same response to your suggested "ECHO" test. I have a second SanDisk 32GB drive that works just fine. I have tried the drive(s) on both XP and Vista machines. I've tried them both at the same time and separately across many reboots, reinsertions and ejections. It thinks it's "locked"
