SanDisk Guru
Re: Ultra Fit USB 3.0: Excessive Heat
[ Edited ]
The goal of the factory format is as a Super Floppy and is designed to maximize the efficiency of the drive.  Windows format does not support the Super Floppy format and may not even care if the drive is removable.  It's just not a goal of Windows format function.
So did you format it as NTFS or exFAT?
It is very possible the overheating problem is a self inflected problem.
Ed
Newbie
Doesn't matter whether NTFS or exFAT, both runs extremely hot.
So what is the "factory format" standard and how can I do this?
SanDisk Guru
You can't. You already burned that bridge when you re-formatted it because you didn't trust the factory format.
SanDisk Guru
For drives less than 64GB FAT32, for drives 64GB and larger exFAT., but all in superfloppy mode with the drive as a single partition. No partition table, no MBR.  And neither format has journaling which NTFS has that adds overhead to a drive.
Ed
Newbie
@Tapeworm: if what you claimed is true, does Sandisk make this clear to the consumer? I do not see any notes neither guidance re. this factory format in the packaging.
@Ed_P: as I informed earlier, using exFAT does not help to reduce the heat either.
Is it anyone from Sandisk in this forum to help to explain this?
Newbie
it's a basic engineering problem. as you put more functional stuff into a smaller space, you get more excess heat. there are workarounds to deal with overheating, but the problem is always present (unless there's a radical change in technology). this is why computers and game consoles have built-in fans, they would overheat and shut down otherwise.
I've had the same issue with my 128gb sandisk ultrafit. the metal gets burning hot when I transfer gigabytes, and even when I leave it in without doing anything, it's hot right after ejecting. it makes sense actually, because they maximized efficiency - with as much speed and memory in as small a space as possible, there has to be a tradeoff: excess heat.
I'll assume on good faith that sandisk is aware of this, and that QC determined that the excess heat is not enough to cause damage to hardware. But naturally it's alarming to the end-user, and I wish they'd been more up-front about this.
In the meantime, I'll still use it, but I'll limit my usage to be on the safe side. It seems to especially heat up in my laptop. I'd think adding ventilation holes would've helped but there could be design reasons I'm not aware of.
SanDisk Guru
"I'll assume on good faith that sandisk is aware of this, and that QC determined that the excess heat is not enough to cause damage to hardware."
Have you seen the photos joeydee posted?
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Sandisk-usb-3-ultra-12gb-falling-apart/m-p...
Ed
Newbie
[ Edited ]
@xcalibur: you said "the metal gets burning hot when I transfer gigabytes, and even when I leave it in without doing anything, it's hot right after ejecting" --- I agree if it gets hot when there is data transfer, but when it is idle doing nothing, what makes it get hot?
In my logic, if it gets hot when idle, it will be no surprise if it overheat and fail when it is "in action" (i.e. huge data transfer). One thing to clarify, did you copy files into it straight away "out of the box" or did you reformat it before transferring anything into it?
My primary concern (which I guess others' too) is whether this excessive heat will damage our laptop (i.e. USB port or burn/melt the palmrest area where the USB port is located)?
Sandisk does provide warranty but only on the stick (which makes sense), not our laptop neither USB port. Therefore I guess many would rather not to use, or at least use with high caution.
Newbie
@Ed_P - those pics didn't show up until I clicked the link. that is a serious malfunction for sure, but I haven't had issues like that yet. you can't rule out the possibility that it was defective and that the heat issue wasn't at fault.
@Chin - it heats up while idle because it's still running. there's much more heat during data transfers.
I didn't reformat.
it hasn't caused any problems for my USB port yet, even though I did big transfers the other day. while I'm assuming the best, I'm still going to use it economically. for more routine data transfers I'll probably use the 16gb flashdrives.
Newbie
Thanks for the clarification xcalibur. This rules out the factor that the heat issue is caused by reformatting the stick (as explained earlier in this topic).
