SanDisk Guru
Re: ULTRA FIT 32GIG USB DOESNT PLAY IN CAR
What does your Car Stereo manual say is the requirements for a USB drive?
Ed
Newbie
Ed P, I'm not even sure how you still have a job with anyone, let alone SanDisk. You are a horrible representative of the company.
I was brought to this thread because I'm having the same problem and the most you have to say is that it's operater error. It's ridiculous!
These are not random cases, it is across the board. I would like to think that you are acting independently and that SanDisk isn't instructing you to deny, deny, deny. But then again, I guess it wouldn't be surprising.
Is there a solution yet?
SanDisk User
For what it's worth, I think Sandisk is continuously finding a solution to this.
Newbie
I have some what same problem playing songs in car usb stereo, but in my case the usb works ok for the very first time but if I change audio input option ( source button) to play radio or cd and then again want to play songs through usb drive it just hangs. The red led light is very bright when playing for the very first time but if I switch to radio or CD then again plays USB the led is very dim and it doesn't play or hangs. IMO its something to do with power managment programe on ULTRA FIT USB which makes this hanging problem.
Newbie
Officially not work on old car audio, only in modern versions. I recommended proceed to execute the official warranty and use version 2.0 for car audio.
Nicolas Zartaryan,
MEGA-IMPORT
Buenos Aires, Argentina
SanDisk Reseller
Newbie
same problem here.  2015 Pioneer head unit, USB skips like crazy.   trancend works fine, except that its huge and my usb port is on the front.  wish i could return this thing but i bought it a while back and just tried it out
Newbie
Same Problem.. Really frustrating... I have Pioneer 2015 headunit... all USB 2.0 work fine. I have tried multiple Sandisk USB 3 drives with multiple formatiing options... Never worked..
Sandisk need to do better job in managing the backword compatibility. Although I must say the drives work fine on all other devices like my SOny TV, Home Theatre etc..
The issue to my mind is USB 3.0 copatibility.
P
SanDisk Guru
Have you checked with the car manufacturer to see if they have an update to their USB 3.0 port?  How about the car's audio device's manufacturer for an update?
The USB 3.0 specs weren't as tight as the USB 2.0 specs when they initially came out.  Different manufacturers could implement support differently.
Ed
Newbie
After years of avoiding SanDisk like the plague at work and vowing never to return after a spait of rubbish flash drives in various mediums that saw massive amounts of data loss all too frequently, is too saw these Ultra Fit drives and thought, what the hell, they're small and I just want something simple for music in the car, so I bought 3 of them, all IDENTICAL.
Two of them are fine in both factory and aftermarket headunits across a range of manufacturers (3 different generations and models of Volkswagen, a Land Rover, and a Pioneer head unit) but one of them outright refuses to work properly in any of the vehicles. It, like everyone elses, skips all over the shop, changes tracks randomly and its utterly unusable for this purpose.
Stop carrying on and telling us it is an issue with the vehicles or the headunits, and acknowledge the fact that SanDisk still produces rubbish, if 2 of the 3 identical drives work, and 1 doesn't, then this is clearly an issue with SANDISK!
Clearly SanDisk products aren't fit for any purpose, certainly not professional use - not even something as simple as storing music in a car. I'll go back to avoiding SanDisk like the plague from now on, never to return.
Newbie
Keep those Ultra Fit 3.0 away from your expensive equipment. I fried two computers by using an Ultra Fit 3.0 on each of them for a week. Never in ten years something like that had happened to me (scientific equipment). I had bought half a dozen for a Wii U, a phone, a Raspberry Pi. Last night I played "Let's smash crappy products with a hammer" with my daughters. I would not want anybody picking them from the trash and fry their wares with them.
