Sandisk firmware
Description: [E:]USB Mass Storage Device(SanDisk Cruzer Glide 3.0)
Device Type: Mass Storage Device
Protocal Version: USB 3.00
Current Speed: Super Speed
Max Current: 896mA
USB Device ID: VID = 0781 PID = 5597
Serial Number: 4C530001170525102524
Device Vendor: SanDisk
Device Name: Cruzer Glide 3.0
Device Revision: 0100
Manufacturer: SanDisk
Product Model: Cruzer Glide 3.0
Product Revision: 1.00
Controller Part-Number: Unknown
(reported from ChipGenius v4.18)
Been around the 'net" and to Sandisk… anyone know of a site to obtain the firmware for this? Oh…it’s a 256Gb drive. Was the Controller Part number purposley 'unknown"?
THANX:
Rick
the FW of USB drives are not field FW upgradeable.
if you are willing to take risk…remove cover from flash drive and read controller number from,control chip directly.or use internet to find serial.then donwload firmware using controller number.
RE:  _ underdeath21 _
_     T _hanx for your response. Ahm… yup, seems the only way to get controller number is to dismantle drive. Just out of curiosity, did you see drlucky’s reply? Well, then, much as I doubt, I’ll TRY to get Sandisk to replace. Wish me luck  LOL LOL:confounded:
thanx for your responses.
Description: [E:]USB Mass Storage Device(USB SanDisk 3.2Gen1)
Protocal Version: USB 3.20
Current Speed: High Speed
Max Current: 896mA
USB Device ID: VID = 0781 PID = 5581
Serial Number: 0401A5FBE799E15CC1623B588A8B5B0D99D248F4FFF020D0DDE428137D71A23E9F1300000000000000000000F6C7A309008D14188155810794A830CF
Device Vendor: USB
Device Name: SanDisk 3.2Gen1
Manufacturer: USB
Product Model: SanDisk 3.2Gen1
How can I know the controller vendor or part number…?
Please help me…
Why would you need it?
Showing no media… In the Device manager
Try a different USB port, try the drive on a different pc. If still having problems, return it for a replacement.
Where can I get drivers for this device?
Hello
I have a 128 GB sandisk ultra dual drive luxe flash drive with otg type C
The problem is that when I connect it to the computer and copy and paste files like movies on the flash drive, the copying process starts with a speed of two to three megabytes, and after a few seconds, the copying speed drops to zero, and it stays like this for a few seconds, and then the copying speed increases again. comes up
This process continues until the end of copying the file
The file transfer speed does not exceed 3 MB
That’s why copying takes so long
Do you think this problem can be solved?
.It sounds like your AV app is checking every byte and that will indeed slow you down. Also be sure your USB port is clean and USB 3.0 if possible
SanDisk Cruzer is Great and nice service
