Sandisk cruzer blade 8gb pendrive is not showing as removeable disc
I was buying sandisk cruzer blade 8gb pendrive at this month, but it was not showing as removeable disc, it showing as Local disc… Please tell me what the reason and how to fix??? please help
If you use the flash drive as a normal storage, a local disk flash drive is OK for normal use.
But if you use it for special purpose, such as a bootable drive or use it on some special devices, then you will need a non local disk flash drive.
