Newbie
Sandisk cruzer blade 32gb - device driver software wasnot successfully instaled over and over!
my sandisk cruzer blade 32gb wont install its driver on my 32-bit windows 7 os. everytime i scan for hardware changes its saids that the device driver not sucessfully installed, i unistall it already, disabled enabled and also restarted my pc and still having this problem over and over. Is there any other way to fix this problem? cause even in disk management the flash disk is not detected.
Newbie
Re: Sandisk cruzer blade 32gb - device driver software wasnot successfully instaled over and over!
Newbie
Newbie
my sandisk cruzer blade 32gb wont install its driver on my64-bit windows 7 os. everytime i scan for hardware changes its saids that the device driver not sucessfully installed, i unistall it already, disabled enabled and also restarted my pc and still having this problem over and over. Is there any other way to fix this problem? cause even in disk management the flash disk is not detected.
SanDisk Guru
You could try a repair install of Windows 7.  http://windowssecrets.com/top-story/win7s-no-reformat-nondestructive-reinstall/
Ed
Newbie
