Newbie
Accepted Solution
Sandisk ULTRA 32GB - LED does not flash
Just bought a SANDISK ULTRA® USB 3.0 FLASH DRIVE 32GB https://ru.sandisk.com/home/usb-flash/ultra-usb.
The operation LED does not flash. On the video from other people in YouTube (https://www.youtube.com/watch?v=dPsoyuWvBW0),
I see how the work LED flashes blue or red. Does my flash drive work properly?
SanDisk Guru
Re: Sandisk ULTRA 32GB - LED does not flash
Does it stay blank when you write to it?
Ed
Newbie
The flash drive works correctly both writing and reading, the testing program passes, errors = 0. But the indicator for some reason does not work. And I need official information from Sandisk - is there an indicator in this flash drive or not, should it work here to blink or is it a Chinese counterfeit? So that I can say in the store when I return the flash drive.
SanDisk Guru
When you return it simply say it's not working as you expected and you would like to try a new one.  Or a different one.
Ed
Newbie
[ Edited ]
The answer came from the authorized representative Sandisk, which says that there are two versions of this USB flash drive: one - has a work LED indicator, the other - without an LED indicator of work.
I got - without an LED indicator of work.
Thank you all for your attention.
