r007
April 24, 2011, 10:13am
1
Hi all
My Usb is Cruzer Micro Skin 4gb FAT32 .
While I was copying a file from 150MB
the copy is locked, the LED is still burning
fixed. I unplugged the memory with the procedure
WinXP SP2, I rebooted the computer, connected
the memory, that was recognized as:
Sandisk S3 Ucl Mode Usb, filesystem Raw 16Mb ,
impossible to format, the Led is off.
This problem is solved?
Thanks at all
Regards
sounds like it is reading the info from the controller. regardless it sounds like a bad drive and would need to be replaced.
r007
April 29, 2011, 11:05am
4
Hi
Thanks
it possible reprogram the firmware?
Regards
PLS SAY SOLITION ON THES PROBLEM
ed_p
November 18, 2011, 11:33pm
8
how u solved this problem ,
as same hit on my pen drive to
with same problem on same pen drive
pls help me at anilonly4@gmail.com
