Newbie
Re: Sandisk Extreme 64GB - Slower write speeds after system format
[ Edited ]
@moogle
>>Using SecureErase in PartedMagic has restored it back to normal
when you said "it is back to normal" by using SE/PM, I'd like to ask you 2 questions on top of this:
  1. are you confirming the read/write speeds are back to the from factory speeds (up to 190 writting/up to 245 reading)?
  2. if yes #1,  what format have you choosen for to get them back (e.g. fat32, extfat, other)?
Thanks,
Newbie
zakear wrote:
@moogle
Thanks,
Hi zakear,
1. Yes, I used CrystalDiskMark to test read and write speeds on two different 64GB drives. One was formatted to NTFS and the other was left as exFAT like when it came from the factory. The speeds were roughly about 32-34 MB/s read and 12-15 MB/s write on the sequential parts of the benchmark. Both drives were performing similarly poor after having been used for a year and filled up many times.
2. After the SecureErase (I booted to linux and used hdparm instead of the gui tool as I couldn't see my flash drive. See this page https://blog.oxplot.com/make-usb-flash-write-fast-again/ on what commands to use.) the drive no longer has a filesystem so I formatted it back to NTFS 4K cluster size using Windows 10.
I went and performed the CrystalDisk benchmark and speeds were back up to around 211 MB/s read and 139 MB/s write which seemed back to normal speeds.
I also tried copying a large file to the drive before and after secureerase in Windows 10 and before I was getting around 3-5MB/s write speeds, afterwards the drive was copying at around 95MB/s for about 10 mins (the time it took the transfer to complete) which seemed about right as I was copying from HDD -> Sandisk drive.
The drive was hot afterwards but back and performing normally. All these posts about ruining the factory partition/sector size is just rubbish. The drive uses SSD flash chips but I don't think there is a controller embedded inside to automatically perform TRIM commands or do wear levelling, which is why the drive will slow down over time with use.
Maybe a majority of users who rarely use the drive to copy large files won't see an issue, but if you use the drive too much it will slow down significantly.
Newbie
Hi !
I've just formated my drive with the Windows tool in exFat (see screenshot below) and I got the same speed as you.
Newbie
Its abit overcomplicated, why u use linux commands when u already secure erased your drive with partedmagic?
I did a secure erase with parted magic like you too, after that i formated my stick with SDFormatter with these options.
Format Type: Quick
Format Size Adjustment: On
Thats it my speed went up again.
The good thing about SDFormatter is he sets the correct alignment automaticly, u can check that with AS SSD Benchmark tool (see screenshot) if there is ok you are good, if there is BAD you are i guess u know it Smiley Very Happy
so i think the stick loses speed if there is a wrong alignment.
ITK
Newbie
Just wanted to let you guys know that secure delete via "hdparm" worked fine for me on Linux.
  1. hdparm --user-master u --security-set-pass Nine /dev/X   <- Enable drive security
  2. hdparm -I /dev/X   <- Check if security is enabled
  3. hdparm --security-erase Nine /dev/X   <- Worked for me without --user-master u,  this will wipe all data in less than 30 sec
  4. hdparm -I /dev/X   <- Verify that security is disabled
dev/X = drive name, for example /dev/sdg
My speeds went from 10MB / sec to over 200MB / sec again Smiley Happy
Best regards,
IT-Technik Klimt
SanDisk Guru
But don't you then have to format the drive?  And for 64GB as exFAT?
Ed
Newbie
[ Edited ]
Just off the phone with Sandisk support. Their USB sticks and memory cards are ment to be formatted.
So, format them if you want for as much as you want. You won't break it by doing so.
Just like SSDs, no way you can physically break your USB disk or have it's performance degraded by formatting it (however obviously you will loose data on it). Well, not as long as you format it 24/7 for a couple of years (wear out memory chips by writing data more times than it's been designed to handle; and those are pretty generous nowadays anyways).
So happy formatting, people!
If the drive performs slowly (or does not work at all) then you should contact the support.
