Newbie
Sandisk Extreme 64GB - Slower write speeds after system format
I have problem with Sandisk Extreme 64GB USB 3.0 Pendrive, I formated it in Windows 7 to exFAT (full format) and now write speeds are slower than before.
How can I reformat it exaclty same like it was by Sandisk ?
Newbie
Re: Sandisk Extreme 64GB - Slower write speeds after system format
I find that information
drive you lose the custom logical block offset which was put in to provide (sometimes radically) improved transfer speeds.
So I need to restore the original file system scheme. Help Sandisk please.
SanDisk Guru
"I formated it in Windows 7 to exFAT (full format)"
Why did you format it?  Why not leave it the way it was?
Ed
Newbie
Because by default was FAT32, and I need exFAT for larger one file size over 4GB.
Newbie
From CrystalDiskMark Sequential speedsOut of box
Read: 203MB/s
Write: 181MB/s
After format in system Smiley Sad
Read: 201MB/s
Write: 159MB/s
I want to get back to previous speeds PLEASE, even with FAT32 file system, I know it's not very big difference now but it's slower and I feel that.
SanDisk Guru
Try NTFS.  it doesn't have the 4GB file limit either.
Ed
Newbie
Nothing help, still slower in write!
BEFORE any format out of box
AFTER format
SanDisk Guru
Thank you for confirming what I have always said.  Don't reformat a new drive unless you absolutely positively have to, large file sizes being the only example IMO.  I think you've gone as far as you can at this point.  If you need 4GB files to fit you have exFAT and NTFS as your options but there is a down side.
You could try enabling the drive caching capability but you have to be very very certain you always Safely Remove any flash drive you use in the machine.
Ed
Newbie
Could You tell me how to get back to previous speeds ?
SanDisk Guru
See if SanDisk will replace the drive.  But you will be back at FAT32 and limited to files 4GB or less.
Ed
