Newbie
SanDisk Extreme USB Flash Drive 128GB show “Bad” and “Remaining Life=0” in CrystalDiskInfo
I bought a Sandisk Extreme 128GB flash drive last month. I checked it with CrystalDiskInfo and it showed “Bad” and “Remaining Life = 0”. I went to the distributor (Synnex) and after 1 week, they exchanged it with a new one.
After arriving home, I checked the new replacement again with CrystalDiskInfo and it showed again “Bad” and “Remaining Life = 0”. So I went again to the distributor (Synnex) and after 1 week, they exchanged it again with a new one.
After arriving home, I checked second replacement again with CrystalDiskInfo and it showed again “Bad” and “Remaining Life = 0”.
I wonder what is the problem with the 3 Sandisk Extreme 128GB flash drives (all new and never been used), since all of them show “Bad” and “Remaining Life = 0” in CrystalDiskInfo. I have a Sandisk Extreme 64GB I bought within the last year, and 2 Sandisk Extreme 64GBs I bought in the last 3 years, and all of them show “Good” and “Remaining Life = 100” in CrystalDiskInfo.
Are there problems with Sandisk Extreme 128GB flash drives? Has anybody experienced this?
Thank you,
EAres
SanDisk Guru
Re: SanDisk Extreme USB Flash Drive 128GB show “Bad” and “Remaining Life=0” in CrystalDiskInfo
[ Edited ]
Have you actually tried any of the drives to see if they work?  Have you written to CrystalMark to see what they suggest?
Ed
Newbie
I have the same problem. Serial number -  sdcz80-064g-g46
Newbie
SanDisk Guru
Newbie
Okey, but I have found screen with good condition of pendrive. What do youu think about this ?
Newbie
I have the same flash drive and have had the problem with the flash saying that I'm out of space when it said I had about 50+gb left the day before, then on top of that, I can't access the locked portion of the disk and I KNOW that I didn't forget my password! So now i get the problem with the "invalid parent path" that apparently San Disk has no answer for.
This is so totally ridiculous! I have many other flash drives and will probably buy many more but I will NEVER NEVER EVER BUY ANOTHER SAN DISK AGAIN!!!!
I just read a bunch of posts trying to fix a locked drive saying "invalid parent path" and have been trying to access my very, very important files on a 128gb flash drive (wow- especially will warn people not to invest in another 128gb or larger drive when they are going to fail!! big money loss on top of time-waster!).
None of the things i've tried have worked.
SanDisk has NO BUSINESS SELLING A FEATURE ON A FLASH DRIVE THAT DOES NOT WORK!!!!!   I hope people read these posts before they ever consider buying one of their products again.
