Newbie
SanDisk Extreme Pro USB 3.1 Format to NTFS
I recently purchased a SanDisk Extreme Pro USB 3.1 memory stick and it is formatted to exFAT. We have some older Windows 2000 computers I need to copy data from as well as some Windows 7 and Windows 10 computers. Will the write/read performance be affected and will the life of the USB Extreme Pro 3.1 be shortened if I format it to NTFS on one of the Windows 7 computers?
Thanks in advance
Tim
SanDisk Guru
Re: SanDisk Extreme Pro USB 3.1 Format to NTFS
Yes.  NTFS is a journeling system and therefore increases the writes to a drive.  There is no advantage to using it on an exFAT flash drive. Windows7 and 10 support exFAT, I don't know about Windows 2000.  If it doesn't there may be a utility that would add that support to it.
Ed
SanDisk Guru
For Windows 2000 this link may help you.
https://support.microsoft.com/en-us/help/955704/description-of-the-exfat-file-system-driver-update-p...
Ed
Newbie
I appreciate the information you provided. Unfortunatly it appears there is no way to use my new Extreme Pro USB 3.1 on the Windows 2000 computers I am required to support. I will re-format the USB stick to NTFS and when the USB stick ceases to function, will purchase another. Formatting to regular FAT 32 will not work either because I am required to copy Windows 2000 backup files from the computers as well.
