PH9
Newbie
Re: SanDisk Cruzer Blade 16GB write protected error
all i need is a solution to fix this properly and permanently becouse im sick of buying a usb which is useless. when i read all of the comment, most of them got the same problem and why dont u justtell us the solution so everybody and be happy about it. everyone who read my comment plz dnt waste your time to write your problem ecouse we all know whatis ur problem anyway and dnt fill the page with full of the same problem. all i need is a solution to this which works 100%. i have tryed everything else such as format, drag in and out all changing in property(advance share). so what is the solution?
SanDisk Guru
If it's under warrantee return it to SanDisk and get a replacement.
Ed
SanDisk Guru
PH9 wrote:
when i read all of the comment, most of them got the same problem and why dont u justtell us the solution so everybody and be happy about it. . . all i need is a solution to this which works 100%. . . so what is the solution?
Don't you think that if anyone (including SanDisk personel) knew a solution that they would post it here?
In other words, there is no known solution other than returning it as defective to SanDisk and getting a replacement.
Newbie
[ Edited ]
This my first Sandisk flashdrive, and it will be the last one. It has been used for only half year in my hand and now it turns to a status of "Protected FOREVER". What a joke!
Robbin
SanDisk Guru
Look on the bright side, you will never loose your files on it.  They are frozen in time forever.
And if you want a drive that is writable your's is still under warrantee.  Return it to SanDisk and they will send you a replacement. Obviously copy your files off of it before sending it in.
Ed
Newbie
i have the same problem here. cannot return drive since it contains passwords and source code owned by my employer.
is never being able to delete those a good thing? seriously i'm tempted to take this to slashdot as sandisk does not seem to be serious about this.
Newbie
I also do not understand why they do not clearly state here the problem and solution, but their customer service is much better, i would say perfect. Due to sensitive data on my drive they allowed me to damage the flashddrive before return (so I did), although it is an exception to their policy. Now a new replacement is on the way to me.
SanDisk Guru
[ Edited ]
I'm pretty sure if you search the forum for "return it to SanDisk" you will find it stated numerous times.
But to state it clearly for you,
If you have a probelm with your SanDisk device and it is under warrantee return it to SanDisk.  Contact SanDisk Customer Service for details.
http://kb.sandisk.com/app/ask
Better?
Ed
Newbie
Here are some instruction :
-Run Registry Editor (regedit).
-Navigate to the following registry key: -HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
-Create a New Key named as StorageDevicePolicies.
-Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
-Double click on WriteProtect, and set its value data to 1.
DONE Smiley Happy
To read more about this try looking here : http://www.techyv.com/questions/how-remove-write-protection-flash-drive
Newbie
ane ammapa me comoany ake unge ammalata 2paara 2paara gaane hukanna ona.. mun nam kari vasalayo tamai...
