SanDisk Guru
Re: SanDisk Cruzer Blade 16GB write protected error
Thanks Graham.
Does the formatting remove the write protection when the drive is used back in a pc?  It was noted in another recent post that the drive could be formatted in a cheap camera but it was still write protected when put back in the pc.
Ed
Newbie
Works fine on my laptop now, tried everything else including registry hacks this is the only thing that worked.
SanDisk Guru
Thanks for the follow up, gdauphin.  Hopefully this helps out many of the others with problems.
Ed
Newbie
[ Edited ]
How you did that? Even this software says it's write protected. I tryed this and HD Tune Pro!!
I Just bought two 16gb sanddisk flashdrives and both of them are with this problem! I bought both on Amazon.
Newbie
Hi, I am propbably 1 of the 1% who have problems with my Cruzer blade 16gb. It is also write protected on its own accord.
This happened maybe a month or so ago & I finally decided to look for a solution or if someone else has this problem. Well it seems I am not the only one.
I do believe alot of people may have this problem, but are not inclined to search the web for a solution or thinking they did something wrong.
The check flash solution did not work for me. It states the obvious: your drive is write protected, remove the write protection first.
We need some customer service & a solution to your product's fault.
It is no use blaming Windows. It is a Sandisk problem.
Please provide a solution. I am looking forward to great customer service & a speedy solution to this problem some of us experience with your product.
Thx
Newbie
pls help to remove write protect from my SanDisk Cruzer Blade 16GB,have tried all methods ,nothing is happing.
whether have to buy another drive other than SanDisk ?
Newbie
nothing is happening with "SanDisk Cruzer Blade 16GB write protected error"
please suggest solution for it.
SanDisk Guru
SanDisk Global Customer Service Contact Information
Retrun the unit to your dealer or contact SanDisk directly via the link provided above for a warranty replacement.
SanDisk Guru
Return it or contact SanDisk directly for a warranty replacement as suggested above.
Newbie
That's not a suggestion. That's just prolonging a problem that you need to actually fix.
