Newbie
SanDisk 32GB not visible after renaming
I have been using a SanDisk 32GB drive to transfer data between Windows and Macs.
All was going well until I renamed the drive before ejecting it from the Mac.  It was then not visible on Windows and not visible when I went back to the Mac.
Any suggestions?
Newbie
Re: SanDisk 32GB not visible after renaming
 Some time pen drive showing in device manger but not in my computer , in other system its showing , so might be possible no drive letter assign for drive > go to control panel > Computer management > disk management > select storage or drive which is not showing > assign letter select any latter after doing above pen drive showing in my computer.
Newbie
The drive is not visible on a Mac or in any location on a PC.
I now think that the drive is faulty and that it was a coincidence that the fault developed just after renaming.
