turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
SanDisk 128GB 2.0 Flash Cruzer Glide USB Drive - Missing SpaceOptions
05-11-2017 07:14 AM I just received my SanDisk 128GB 2.0 Flash Cruzer Glide flash drive today. When I plugged it into my computer it only shows 116gb. I understand not all flash drives is going to be at full capacity. However, I'm missing 12gb on the flash drive, that is way too large amount to go missing.
Is there something wrong with my USB flash drive? Is this a regular thing to happen for model flash drive like this? Re: SanDisk 128GB 2.0 Flash Cruzer Glide USB Drive - Missing SpaceOptions
05-11-2017 08:12 AM no nothing wrong with the drive. this is due to the conversion from decimal to binary.
https://kb.sandisk.com/app/answers/detail/a_id/46/
All SanDisk products include the total capacity, at an unformatted level, that is stated on the product packaging. For example, a 128GB SanDisk USB flash drive has a total capacity of 128,000,000,000 bytes at the unformatted level (where 1GB=1,000,000,000 bytes).
Definitions of a Megabyte:
Note: Some capacity is used for formatting and other functions and thus not available for data storage.
A portion of the total capacity is used to store certain functions including optimizations of the memory that support performance and endurance and therefore is not available for user storage. This is disclosed on our packaging and marketing materials when you see the statement "Actual user storage less."
As a leader in flash storage technology, SanDisk offers multiple products at different speeds and capacities to address a variety of consumer needs. To provide the optimum product for you, we're continuously improving and updating our technology, products, firmware, and design. Continual improvements and updates are made to our product (both new products and existing product lines) and can include changes to the basic file structure, formatting and other functions. These optimizations may result in variances as to the amount of memory space that is available for user storage, but are essential to performance and endurance of the products. |
