PROBLEM WITH 16GB SANDISK USB FLASH DRIVE
Hello everyone!
My name is Alex, and I’m having some issues with my 16GB SanDisk USB flash drive. When I connect it to my car radio, it is always starting at the very beggining of the track list. It doesn’t remember which song I was listening to, and I guess this is happening because I’m missing some sort of cache file or something like that, which could make the radio remember where were we.
How could I fix this?
Thanks in advance!
in that case i would like to ask if you are using the Ultra fit with the car radio as this drive has some known issues with car stereos. If not then i would suggest formatting the drive on another format like NTFS or FAT32 to be nativelly supported by the car stereo.
i hope i could help in that case.
Yeah, is the ultra fit one. What are those known issues? Should I do something, or just accept i did a bad bargain
Thanks!
in that case Sandisk can replace it with a drive that has the firmware fix with it so you can use it normally. So i suggest get in contact with them under this link
http://www.sandisk.com/about-sandisk/contact-us/
Ok, I’ll do. I will let you know if everything gets solved.
Thanks!
