Newbie
Accepted Solution
LG Smart TV does not detect new Sandisk Cruzer Glide 64 GB
As per title
I have already formatted the key (which i bought today) to NTFS and it won't automatically show on my LG menu when i insert it.
PC Windows 10 detects it just fine. The LG TV software is up to date. I have already tried rebooting the tv and trying different ports.
I have a few other NTFS Sandisk pendrives (Cruzer Edge 32 GB) that always worked with zero problems.
I cannot use FAT32 because some of the files are too large.
Please advise.
As always, i deleted the Sandisk security folders because i don't care about those before formatting. However, the deletion process hung up at about half completion for a few seconds, which is unusual.
Could it be that the pendrive is now treating any of the files i put on it as secure content?
SanDisk Guru
Re: LG Smart TV does not detect new Sandisk Cruzer Glide 64 GB
[ Edited ]
hmmmm
According to this LG link the TV does indeed support NTFS format drives. http://www.lg.com/hk_en/support/product-help/CT20136005-1436499459857-connecting-external-devices
But it also says:
"It is recommended that you use a USB Flash Drive of 32 GB or less or a USB HDD of 2 TB or less."
and
"It is recommended that you use a USB hub or hard disk drive with a power supply.
(If the power supplied is not sufficient,  the USB storage device may not be detected properly.) "
For more information try this link http://bfy.tw/FQy1
Ed
Newbie
Try formatting it as exFAT.
Newbie
[ Edited ]
Yeah, i actually solved it by trying exFAT shortly after posting yesterday.
Thanks anyway for your replies.
Newbie
solved it by trying exFAT too.
SanDisk Guru
Glad to hear those old responses helped you carla.
Ed
