SanDisk Guru
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE???
[ Edited ]
Newbie
Same here,. i'll guess i wont return it, glad i bought two on black friday.  will wait for a solution,.
Newbie
Use GPARTED in Linux. Delete the partition table and then format it using whichever filesystem you prefer. Linux gives no craps.
Newbie
After following the whole process, I have not seen StorageDevicePolicies after "Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"  so, what should I do to format my 8 GB SanDisk Pen Drive?
Newbie
if you will still face this problem try this video method to solve your problem
https://www.youtube.com/watch?v=aSfWfvugqic
Newbie
To format pen drive it is must to remove write protection. There are various ways to remove write protection from pen drive but i am going to tell a way by using command prompt. I am leaving a link https://windowsclassroom.com/best-ways-remove-write-protection-pen-drive/ here, it will defintely help you to remove write protection.
Newbie
hi man
i had the same probleme
and this worked with me
just install the reg file to disable write protect
https://drive.google.com/file/d/0B1Y9NvUQRfxcaGJhcVNBV2gwaEU/view
good luck
