SanDisk Guru
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE???
Return.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
Removal not possible.
Ed
Newbie
Here are few links where you can get the problem refer and fix your issue
Please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
or
http://www.techyv.com/questions/how-remove-write-protection-flash-drive
or
On the usb flash drive its self there may be a switch that will add or remove copy protection
If you are sure that there is no write-protect switch. You can try low-level format it.
http://m3rlinez.blogspot.com/2007/01/just-rescued-my-write-protected-usb.html
Regards
Sharath
Newbie
Newbie
i have problem with my SANDISK,USB FLASH-DRIVE(8GB) that whenever i insert or plug it with some computer and try to write(CUT,COPY etc) it shows an error that THE DISK IS WRITE PROTECTED..can any one please suggest that why it is displaying such error...at first i think that this is problem with my pc but know the essue is same for all computer..
can any help me to resolve this issue???
SanDisk Guru
Have you read any of the previous replies in this thread? Smiley Frustrated
SanDisk Guru
"can any one please suggest that why it is displaying such error.."
It's broken.
"can any help me to resolve this issue???"
Yes, return it.   http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
""Have you read any of the previous replies in this thread? :smileyfrustrated:"
Obviously not.  Smiley Sad
Ed
Newbie
BEFORE YOU RETURN IT
If you have windows....
run command.com (just do a search for it it will be there)
In the old school command line box that no one seams to care about anymore type
chkdsk e: /F /X
where e: is the drive letter assigned to your usb stick.
Wait for a few minuites at most and you will probably have a perfectly writeable usb stick even if no errors were found.
Worth a try to saves days of waiting for a replacement in the mail or a trip into town.
Newbie
my scandisk usb 16gm i can open or save any file from that usb please help me a simple solution for open it
Newbie
SanDisk Guru
Option #1
Option #2
Option #3
