SanDisk Guru
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE???
You're not alone.  Read this post and the one following it.
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Cruzer-32Gb-Flash-driver-write-protect-err...
Ed
Newbie
Step 1:
One more thing to check:
> Click Start->Run, enter: regedit
> Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
> Does sub-key StorageDevicePolicies exist? If yes, right click to delete this sub-key
Step 2:
insert the USB device, then
control panel->Admin Tools->Disk Management
Your boot drive will show as C:\ and under
Layout will be Partition
File System will show NTFS
How does your USB show up?
Step 3:
So if you go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
look for StorageDevicePolicies -- if found, open it and look for WriteProtect - - delete the key
Step 4:
Try this ..it definitely works...I found it after lot of research online..
http://www.pny.com.tw/index.php?cls=2&mode=download
download and use Ufix-II
all the very best !!
i have done these all but problem is same.....
plzzzzzzzzzzzzzz tell me what should i do now....
SanDisk Guru
[ Edited ]
Do you have a PNY, HP or SanDisk flash drive?  If you have a PNY or HP drive did you try their RMA link? http://www.pny.com.tw/index.php?mode=repair
If you have a SanDisk flash drive try this link:
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/HOW-TO-REMOVE-WRITE-PROTECTION-FROM-USB-FL...
Ed
Newbie
dear team
i want
remove the password but i don't no password
Newbie
My usb pot is not  working, always asking the write protection so please help me .
SanDisk Guru
"please help me"
Read the posting 2 above yours.
Ed
Newbie
i have the problem to format sandisk pendrive...the pendrive show the disk write protected...when i follow step make easy to reformat pendrive write into Start > Run > type ‘regedit...bla bla...but my computer can't see StorageDevicePolicies at the end...so what can i do to  make my pendrive see this word and can format as usual...tq
SanDisk Guru
yussop wrote:
i have the problem to format sandisk pendrive...the pendrive show the disk write protected...so what can i do
Read the reply 4 above yours (#33).
Newbie
I don't know about others, but the drive worked fine this morning when I uploaded files from an XP box
That after noon, on a Win7 machine - it won't accept writes or delete.
Meanwhile, the other two have been merrily writing and deleting from all three machines (xp, vista and win7).  Not reasuring to have a functional drive suddenly "quit" functioning when you need it.   (In this case, I did not happen to actually "need" it.)
Newbie
Dear sir,
The subject is 8GB USB drive right protected. Removal?
