SanDisk Guru
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE???
ayukjoel wrote:
                       i have aproblem with my8GB  flash drive any time i plug with it to a computer and try to  writte any (cut,copy it shows that it is write protected please tell me what to do
Follow the link in the post just above yours. It has specific instructions on how to solve this problem.
Newbie
Newbie
Newbie
re= how to remove write protection scandisk pen drive 16 gb in win xp
SanDisk Guru
Newbie
i have San Disk Cruzer Blade USB Device 8GB
1.the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
  The value 'WriteProtect' should be absent or set to '0'.
2.Write protection ON or OFF button on stick then
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (F8) key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
3.USB Storage write protection (Fix)
1) Start > Accessories > Run Command Prompt As Administrator
2) type > >chkdsk t: /F /X
(use your own drive letter where f: is)
4.Low Level Formatter  software
5. disk getory recover
6. Hard disk washer
7.partition manager
8.Active kill disk
i followed all these files and software and many cmd command  but could not remove write protect ....what do i do?
Newbie
can you make any new setting for San Disk Cruzer Blade USB Device 8GB
just like sand disk write protect formated
SanDisk Guru
prshraj wrote:
. . . but could not remove write protect ....what do i do?
Click on the link in the post above yours and follow the advice given.
Newbie
Newbie
Sorry, but simply returning the drive is not working for me.  Due to the nature of my work, I can not simply hand over my faulty drive and receive a new one, as the data on the drive can be read by ANYONE!!.  There has to be a way to fix this PLEASE.  I'm an accountant and are working with sensitive data!!
