SanDisk Guru
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE???
zakarumita wrote:
... the warranty life is valid for my Ultra II 8GB SDHC card too? (I bought it late in June 2008 when I purchased my camera together the SanDisk MicroMate SD/SDCH Card Reader)
From the SanDisk site:
The SanDisk Ultra SDHC and SDXC Class 6 Memory Cards are backed by a lifetime limited warranty** .
Newbie
Newbie
Re: HOW TO REMOVE WRITE PROTECTION FROM USB FLASH-DRIVE cruzer edge 4gb
pls just me
Newbie
 have problem with my SANDISK,USB FLASH-DRIVE(16GB) that whenever i insert or plug it with some computer and try to write(CUT,COPY etc) it shows an error that THE DISK IS WRITE PROTECTED..can any one please suggest that why it is displaying such error...at first i think that this is problem with my pc but know the essue is same for all computer..
can any help me to resolve this issue???
My Computer config--windows7(64-bit
SanDisk Guru
[ Edited ]
The only solution is to replace the drive.  Either return it to where you bought it or return it to SanDisk directly.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
Ed
Newbie
Like all the others I read leading me here. I can't get write protection removed from my 8gb sandisk flash (pen) drive.  I've tried registry entries, reformatting in windows, reformatting in safe mode, and using computer management and nothing works.  I'm about ready to toss it out, but it has some files I want and it was a Christmas gift last year from my son.  Any other solutions?
Sincerely,
Mary
SanDisk Guru
R e t u r n  i t !!
1st copy the files on it to your hard drive.  Then contact SanDisk for an RMA.  Then RETURN IT.  They will send you a new one that will work, copy the flash drive files you backed up to your hard drive to the new replacement flash drive. Voila, fixed.
Or if it has sentimental value since your son gave it to you, put a lanyard on it and wear it as a necklace.  It won't work but you will have it and can show it to him whenever he comes over.
Ed
Newbie
i have problem with my SANDISK,USB FLASH-DRIVE(8GB) that whenever i insert or plug it with some computer and try to write(CUT,COPY etc) it shows an error that THE DISK IS WRITE PROTECTED..can any one please suggest that why it is displaying such error...at first i think that this is problem with my pc but know the essue is same for all computer..
My Computer config--windows7(64-bit)
SanDisk Guru
Newbie
                       i have aproblem with my8GB  flash drive any time i plug with it to a computer and try to  writte any (cut,copy it shows that it is write protected please tell me what to do
