Newbie
Flip Removable Bit on Extreme USB 3.0 - To create multiple partitions
Moving from 32GB USB 2.0 thumbdrives to 64GB USB 3.0 drives.  Purchased a SanDisk Extreme 64GB as a test - and thus far it is failing miserably.  I did some searches here and while there are a few interesting "work arounds" none address the exact issue I have.  Here is what I have created before and am trying to recreate on the larger USB 3.0 platform:
  • Creating about 20 of these to share with a group of users.
  • Solution must work on Windows 7, Windows 8, Mac Mountain Lion, various Linux flavors.
  • Thumbdrive with two partitions.
  • First partition is 5GB.  Second partition is remainder of the the drive.
  • Both partitions are primary partitions.
  • Neither partition is bootable.
  • First partition contains "public" files, including software for all platforms to encrypt/decrypt.
  • Second partition is entirely encrypted.
  • For compatibility reasons with our enterprise FDE solution the concept of using TrueCrypt with the encrypted file container is not viable.  There is no recovery key in the case of a terminated employee, etc.  (Enterprise admin's will understand this need immediately)
The goal here is to be able to place encrypted files in the second partition, share the drives amoung anyone in the user group regardless of platform they are using, include the software they need for their platform in the clear.
The methods I have read include things like "Windows 8 Enterprise allows Windows on the Go on thumb drives" (not applicable here) and "You can add a driver/filter" (works great on Windows and a single machine - not applicable here), etc.
The Lexar solution, BootIt, works on our old USB 2.0 drives - essentially flipping the "removable bit" to "fixed disk" and hence all computers see it as a fixed disk.  This utility does not seem to work on the SanDisk drives.  The SanDisk Extreme's were chosen due to performance and cost reasons so the first choice is to get this to work.  Otherwise need to go to a different brand.
Anyone find a solution to this?
Newbie
Re: Flip Removable Bit on Extreme USB 3.0 - To create multiple partitions
ChipGenius v.4.00.0027 reports this thumbdrive as follows:
Description: [U:]USB Mass Storage Device(SanDisk Extreme)
Device Type:  Mass Storage Device
Protocal Version: USB 3.00
Current Speed: Super Speed
Max Current: 400mA
USB Device ID: VID = 0781 PID = 5580
Serial Number: AA010118130644195412
Device Vendor: SanDisk
Device Name: Extreme
Device Revision: 0010
Manufacturer: SanDisk
Product Model: Extreme
Product Revision: 0001
Controller Part-Number: Unknown
Newbie
Did you get any further with this? I'm having similar problems...
SanDisk Guru
According to SanDisco who spoke with SanDisk and they said all new flash drives are configured as Fixed Disc.  So try to find one(s) recently manufactured.
Ed
SanDisk Guru
[ Edited ]
not all new drives. Microsoft has a requirement for Win 8 certifacation that USB flash drives be fixed disks so you will need to look for a drive that has the Win 8 Certifacation logo.
Newbie
I have just bought TWO of these 64GB drives, only to find out (after unpacking both) that these are marked as "removable".
I want the opposite functionality, basically what the new model is doing.
Come on, Sandisk, this is just stupid. Same product with different configurations? No wonder you´re getting yelled at in your own forums.
Please post a utility that allows your users to flip the removable/fixed bit on these drives. You're potentially making half of your customers really angry.
Thanks,
larsk103
