Newbie
Extreme PRO USB 3.1 256 GB, Remaining Life = 0, Temp = 8°C, SMART infos
I have bought 2 new USB 3.1 Extreme PRO 256 GB via 2 different e-commerce channel (Amazon & eBay).
When looking at the Device Infos with different Tools I am very surprise that the SMART infos does report:
a Remaining Life = ZERO
and also
a constant Temp = 8°C
Before to RMA these USB keys I would like to know if any users got the same bad experience.
I do use Extreme PRO USB 3.0 128GB without any problems for a long time and SMART infos are quite correct.
Do I have to suspect all the USB 3.1 Extreme PRO manufactured recently and sell on the planet ?
SanDisk Guru
Re: Extreme PRO USB 3.1 256 GB, Remaining Life = 0, Temp = 8°C, SMART infos
CrystalDiskInfo is a hdd measuring tool.  Flash drives are not hdds.
Ed
SanDisk Guru
this USB drive does not support app the SMART attributes the CDI has options for so it does not know what to display. typically no USB drive will ahve full SMART support.
Newbie
Hello drlucky,
What are you telling ? Why Sandisk USB 3.0 64GB and 128GB does support the SMART attributes ?
Are thinking USB 3.1 products family should offer less than USB 3.0 products family ?
