turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Error opening vault on Cruzer Glide 8GBOptions
04-11-2017 04:12 PM I'm getting the following error when I try to open a vault on an 8GB Cruzer Glide:
"An error occurred. Please make sure you have enough space on your external device and you are not launching the application from a zip file."
This is NOT a password issue. The drive properties are showing ~9.9GB free space and RunSanDiskSecureAccess is being run directly from the drive (not from a zip file). My OS is windows 10. This is the only vault on the driver, how can I recover from this error? Re: Error opening vault on Cruzer Glide 8GBOptions
04-11-2017 11:09 PM "on an 8GB Cruzer Glide:"
"The drive properties are showing ~9.9GB free space "
Anyone else see a problem with these two statements? I can see why SecureAccess is having a problem.
Ed
Important files = Backed up files Re: Error opening vault on Cruzer Glide 8GBOptions
04-12-2017 11:00 AM Typo, should've been ~6.9 GB. Re: Error opening vault on Cruzer Glide 8GBOptions
04-12-2017 02:15 PM :-( Then I have no idea why you are getting that error. Sorry.
Ed
Important files = Backed up files |
