turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
EXTREME HEAT with Sandisk Extreme Go USB 3.1 Flash Drive 128GB - SDCZ800-128G-G46Options
12-30-2017 05:31 PM TLDR; I tried to use this device as a bootable OS drive for Windows 10 while it was plugged into a USB 3.0 port. The heat was so intense that it literally bent the plastic/metal USB plug. ![]() Re: EXTREME HEAT with Sandisk Extreme Go USB 3.1 Flash Drive 128GB - SDCZ800-128G-G46Options
12-30-2017 05:32 PM Picture 2 ![]() Re: EXTREME HEAT with Sandisk Extreme Go USB 3.1 Flash Drive 128GB - SDCZ800-128G-G46Options
01-01-2018 04:07 PM Yes, they can get hot, very hot. Are you sure there was nothing under the drive pushing it up?
Ed
Important files = Backed up files |
