d0r
Newbie
Difference between Cruzer Glide / Force / Edge
[ Edited ]
What is the difference between the following 3 DOKs:
  1. Cruzer Glide 8GB SDCZ60-008G
  2. Cruzer Force 8GB SDCZ71-008G
  3. Cruzer Edge 8GB SDCZ51-008G-B35
With which DOK you can view HD videos?
SanDisk Guru
Re: Difference between Cruzer Glide / Force / Edge
all three of these are entry level non performance drives. viewing HD video from them should not really be a problem as HD video only uses about 12MB/s read speeds. if you are planning on using these in some sort of video display device and looping video these are probably not a good choice though. If you are looking for a performance drive look at the ultra or extreme lines.
